LS1 Tranny Help Needed
Old Jun 17, 2004 | 12:04 AM
RedHottG2's Avatar
I posted this in the tranny forum and I'm not getting any responses there so I thought I would see about here. I need to know if I use a 3200 stall and a tranny cooler of course, should I get a shift kit. Or can the shifts be firmed up with programing. Is a shift kit worth it or a wast of $$. Thanks guys!!
Old Jun 17, 2004 | 12:17 AM
mullettour's Avatar
I have a 3200 stall in my trans without a shift kit and it seems to shift fine to me. However, if you want to firm up your shifts I would recommend a shift kit rather than using computer programing. Changing the shift firmness using programing mainly just increases line pressure which generally causes more heat. With shift kits it increases flow through the valvebody and decreases the shift time.
Old Jun 20, 2004 | 12:30 AM
Pro Built Automatics's Avatar
Go to http://pro-built.net/index.cfm?fusea...t&productid=91 this should give you what you want. Let me know if I can be of help?
Parts Wanted
Mar 17, 2015 11:24 PM
HectorM52
Parts Wanted
Feb 11, 2015 09:33 AM
NED4SPD
Sep 16, 2002 10:45 PM
mjcent922
Jul 27, 2002 12:42 PM
