transmission cooler line, where to buy it?
Old Mar 30, 2010 | 10:49 AM
nosliw's Avatar
hey
it is my first post, so I guess I have to make a small presentation. I lived in Illinois then in Texas. Now I'm back in Europe between France, Germany and Austria.
I shipped my Camaro Z28 '93 to Europe when I left America.
I loose some transmission fluid from the cooler line.
I want to change it for a new one but I'm not able to find one on internet already assembled.
I contacted a GM dealer but they sell it in "parts".
In Europe, automatic transmission are not very popular.
Do you have any idea to buy one like the original one and assembled???
Thank you very much for any answer
Old Mar 31, 2010 | 07:03 AM
redneckgames's Avatar
you can try to contact Year One.
Old Mar 31, 2010 | 07:48 AM
...or you can just make up some braided lines to replace them...
Old Mar 31, 2010 | 03:49 PM
koolaid_kid's Avatar
My choice, especially since you are located outside the US. Buy a fitting for the cooler (IDK the size, I no longer use the stock cooler) and a fitting for the transmission, and then braided line to go between the two. You would be better served to go with an external cooler anyway, now sounds like the time to do it.
Old Apr 1, 2010 | 08:50 AM
nosliw's Avatar
thank you very much for your answers
ok but i thought it couldn't be reliable because of the pressure but if you tell me it is good. I will try that.
Ok I will try that as well
thanks again for your help !
Old Apr 1, 2010 | 05:23 PM
nosliw's Avatar
someone has any idea for the size of the braided hose? (Diameter)
I found that:
http://www.racerpartswholesale.com/p...l_Braided_Hose
the diameter is around: 5/8" ?!
Old Apr 1, 2010 | 10:08 PM
I run -6AN lines on a TH400 with fan-assisted outboard cooler, set up for 800HP/800lb-ft. -10AN would be overkill.
Old Apr 3, 2010 | 06:00 PM
nosliw's Avatar
ok, thanks for the pictures
I gonna follow your advises
Old Apr 3, 2010 | 07:57 PM
nosliw's Avatar
I still have a few questions
by the way, with your fan-assisted outboard cooler, do you still use the original cooler system in the radiator???
I can't find a kit with hoses and fittings and I 'm scared to make a mistake when I order the hoses and the fittings. (if I do it from different websites or companies)
Injuneer, your installation looks VERY nice ! Can you tell me where you found your parts (fittings, line and cooler?). I was on summit, jc whitney... I can't find something good. I found russel for the hoses.... I just need the fittings if you know a website
sorry to ask you that but GM had some problems last years and they don't supply Europe anymore in parts it could be better in the next years normally. but at this point it isn't easy to find American parts in Europe.... so I have to find them on internet
ch3vyb1gbl0ck
Classic Engine Tech
Oct 23, 2023 08:07 PM
jackpawt883
Feb 26, 2015 09:04 PM
cmdeshon
Dec 12, 2014 10:51 PM
thenewkid
Nov 27, 2014 09:41 AM
