Trans temp gauge won't work
Old Oct 2, 2003 | 08:46 PM
94-3.4's Avatar
Unhappy Trans temp gauge won't work
I recently aquired a stewert warner electric trans temp gauge. I installed it along with a fuel pressure gauge. I put the sender in the tranny cooler line. The fuel pressure gauge works fine but the trany temp gauge just pegs to zero when i turn the car on. Can't seem to find anything wrong with the wiring either. Any ideas?
Old Oct 2, 2003 | 10:52 PM
Not exactly sure where your sending unit is, but is it grounded?
Old Oct 3, 2003 | 12:03 AM
94-3.4's Avatar
Well, it is not grounded. The sender has a provision for one wire. I got the idea to try and ground it so what i did was connect a wire to the brass housing to the chassis and hold it there while someone turned on the car. The gauge pegged at its maximum temp so i don't know whats going on there.
The sending unit is in a brass t fitting with barb ends on either end placed inline with the incoming trans cooler line.
cmdeshon
Dec 27, 2014 10:06 AM
brentbrowning01
Dec 16, 2014 06:35 AM
ro2207
Dec 4, 2014 06:18 PM
Rich_z28
Aug 29, 2002 10:44 PM
Rich_z28
Aug 27, 2002 12:20 AM
