Towing question
Old May 17, 2004 | 07:45 PM
TEG99SS's Avatar
Towing question
I am planning on towing my car with a tow dolly.
I have heard rumors of the driveshaft having to be disconnected . . . does anyone know why?
The car is an M6, I am planning on towing about 150 miles one way for some track time, the use of the tow dolly would make my life easy.
Old May 17, 2004 | 09:26 PM
Capn Pete's Avatar
If the car is an automatic, then yeah, you can't tow it far without having to pull the DS and plugging the tail of the tranny 'cause you'll overheat the tranny from turning it without the oil pump running (needs the motor running to work).
AFAIK, you could go as far as you want with a standard, 'cause the gears are just submersed in gear oil, and it's no different towing them than driving them? I might be wrong about that though??
Old May 17, 2004 | 09:29 PM
Ekof96Z28's Avatar
Couldnt you just back the car onto the dolly and they the front wheels go free? as long as the steering lock is on it should be ok right?
Magenta_Hearts
Mar 29, 2017 08:54 PM
Magenta_Hearts
Mar 25, 2015 10:24 AM
BPS
9
Mar 5, 2015 10:51 PM
eazyZ
Mar 1, 2015 07:12 AM
97Z28Muscle
Feb 6, 2015 10:44 PM
