th400 and my 95 speedometer working together?
Old 10-12-2009, 11:47 AM
jasonisdn's Avatar
i put the new gear in the tail shaft and sensor in my th400. well when i run around 30 or so it is on or around 100mph. can anyone help me with the numbers that are needed in LT1-edit? so i don't have to keep playing with them.
jasonisdn is offline
Old 10-14-2009, 01:27 PM
jasonisdn's Avatar
ok lets try this then. i had a m6 in the car and went to a th400. the signal is so far off its unreal. the ecm has tables in it related to mph. so without a speedometer would it not affect the car? so has anyone used a little black box to change the signal before it gets back to the ecm, to correct this issue. i know its easy to say put a a4 tune in the ecm but i am using lt1edit and it is vin locked. so i cant change the vin on the stock bin files i have found, so i can do that.
Old 10-14-2009, 09:05 PM
Moderator
rskrause's Avatar
I can't remember the number, but it just took a few iterations of "playing with it" to get it right.
Rich
rskrause is offline
Old 10-14-2009, 09:29 PM
jasonisdn's Avatar
did you just select speedometer and adjust it only or mess with the rear gear also? thanks for any help Rich.
Old 10-14-2009, 10:33 PM
Moderator
rskrause's Avatar
Just the speedo settings.
Rich
rskrause is offline
Old 10-15-2009, 05:23 AM
Since your car an M6 before the conversion, the PCM is expecting 17 pulses per output shaft rotation. You need to program the PCM as an A4. The A4 (and likely the VSS you used on the TH400) puts out the same 40 pulses per output shaft revolution as a 4L60E.
That would mean with the M6 program, your speed is indicating 40/17 = 2.35 X the actual speed.
If you don't want to reprogram, Dakota Digital makes a signal converter box.
Injuneer is online now
Old 10-15-2009, 05:48 AM
jasonisdn's Avatar
thank you both for taking the time to answer.
Old 10-17-2009, 09:10 AM
Vince @ FLT's Avatar
Try to contact these guys. http://www.jagsthatrun.com/
They helped me out with a customers car and their stuff worked great for me. Ask for Greg and tell him I sent you! Vince Bielanski
Vince @ FLT is offline
Old 10-17-2009, 09:19 AM
jasonisdn's Avatar
thanks vince.
RUENUF
05-25-2016 08:10 PM
cmyname1
02-19-2015 08:38 PM
sdn1997rs
12-30-2014 08:30 AM
07-04-2005 05:00 PM
Quick Reply: th400 and my 95 speedometer working together?
