TCC lockup problem
Old Jul 19, 2009 | 12:36 AM
96HawkCnvt's Avatar
TCC lockup problem
Hoping that someone here can help with this. I recently installed a 4L60E from a '95 B-body into a '94 Z28. I chose to run a wire for the PWM control of the TCC rather than pinning the valve & unplugging the solenoid. And of course I loaded a '95 file so that it can control the TCC.
Problem that I'm seeing is that the TCC seems to cycle on & off rapidly (1-2 seconds) when cruising at about 45-50 mph. I checked the file & the TCC engage is set for 46 mph & disengage set for 44 mph in 4th gear with relatively low load. When I had it at about 70 mph on the highway, it seemed as though it was staying locked up.
Also, I will do some further testing but I don't think it is locking up in 3rd gear and from what I see in the programming, it should be. One other thing; I believe that it was a bit low (quart or so) on fluid when it was acting up. Could that be the cause? I haven't driven it since filling.
Any help would be greatly appreciated.
Todd
Old Jul 20, 2009 | 08:14 AM
96HawkCnvt's Avatar
Anyone have an idea on this?
Old Jul 20, 2009 | 02:18 PM
Hal Fisher's Avatar
That must be too tight between the parameters. Stock is 58 to engage and 44 to disengage. I had mine engaging at 45 but releasing around 35 which seemed to work OK.
Hal
Old Jul 20, 2009 | 05:11 PM
46/44 is not "too tight".
The lockup is split into TPS %, so you need to know what % throttle the difficulty is occurring.
46/44 is stock and 58/44 is stock, but so is 77/44. It all depends on TPS %.
Old Jul 20, 2009 | 05:16 PM
Hal Fisher's Avatar
I thought the performance tables were only for the model that has the performance switch (firebird?).
Hal
Old Jul 20, 2009 | 06:42 PM
Hal
I don't see anyone referencing performance mode tables in this thread. What I posted above is from the normal mode tables.
Even the Camaros that don't have the switch, still have the performance mode tables in the PCM.
liamcg97
Nov 25, 2019 05:55 PM
AlaskaZ28
Apr 17, 2015 08:54 AM
Kyle@CSS
Sep 14, 2002 04:06 PM
z28projects4ever
133
Jul 26, 2002 01:54 AM
