swapping gears
Old Jan 29, 2006 | 11:26 AM
hulettsz28's Avatar
swapping gears
What all is involved in swapping my gears? I will have the local Chevrolet/GM dealership do this, but if i just buy the Richmond gears that i want (342's) can they just put them in or do i need to buy other parts?
:-d
Old Jan 29, 2006 | 11:31 AM
infinitebird's Avatar
Re: swapping gears
What gears do you have right now? If it's 2.73s then you'll either need a 3 series posi or the "thick" gears for that one. Otherwise, yeah the gears should be all you need.
Old Jan 29, 2006 | 11:44 AM
LUDA0840's Avatar
Re: swapping gears
wow the local dealership? how much is that gonna run you?
Old Jan 29, 2006 | 11:50 AM
31coupe's Avatar
Re: swapping gears
I just sold a 3.42 posi axle from a low mileage Z28 for $200, look around & you can find deals on complete axles that you could swap out in a few hours in your driveway & use the money you saved to by things to help break the new one with
Old Jan 29, 2006 | 12:01 PM
hulettsz28's Avatar
Re: swapping gears
The code in the glove box is GU2, as my memory serves me anyways, and that is the 2.73's. However, the previous owner told me that the car had 3.08 gears. So...Im not very sure. I know the methods to have it checked, Im not that concerned with what I have now, I am interested in what I need to do to have them installed.
As far as the dealership, much like every other story about getting work done at a dealership I have heard, my friend works there. The shop is Hometown Chevrolet in Whitehall NY, The owners grandson is a camaro nut with a 94 much like myself, and he completely willing to help...So I really dont know how much it will cost to have them put in because I havent asked him yet, Im sure it wont be too much though. :-)
Old Jan 29, 2006 | 12:59 PM
Re: swapping gears
My point is, what you will need depends on what you have now.
Old Jan 29, 2006 | 08:18 PM
robb4964's Avatar
Re: swapping gears
You will need the gears, pinion shims, carrier shims, crush sleeve, pinion seal, pinion nut, ring gear bolts, cover gasket, and pinion & carrier bearings
If you have someone install them make sure you get a reputable person. If someone puts the gears in that dont really know what they are doing or if they dont take time to check the patterns and measurments to make sure everything is positioned right, your rear end wont last long and it will be noisy. Luckily for me one of my best friends is a great mechanic and he has helped me with every gear install. To do it right takes time but its worth it in the end.
Old Jan 29, 2006 | 10:46 PM
Re: swapping gears
PLEASE post on the correct forum.... "gears" belong on "Drivetrain", not on "LT1/LT4 Engine Tech". Moving.....
Zee man
Feb 12, 2015 07:07 AM
rocketman051894
Jan 30, 2015 03:23 PM
ddr698
Jan 9, 2015 10:05 AM
Jul 4, 2005 05:00 PM
