Strongest drivetrain on a budget?
Old Apr 30, 2004 | 10:07 PM
Greasepunk's Avatar
Just wondering what kind of driveshaft and rearend to get that won't fall apart draggin...
Old May 1, 2004 | 05:33 AM
rskrause's Avatar
Moderator
A stock steel shaft is way stronger than a stock aluminum shaft and you already have it, so it's "free". You are stock with the rearend. I guess one of those fancy covers may be of some help, but with hard launches on sticky tires it will not last in an M6 car. It may do ok with an automatic though.
Rich Krause
Old May 1, 2004 | 08:52 AM
Derrick Redd's Avatar
Stock steel driveshaft and upgraded 10-bolt. Best time in sig with some tire spin out the hole. Best 60ft. of 1.55.
Old May 1, 2004 | 10:48 AM
Z28Nut's Avatar
I'm running an Inland Empire 3" al shaft with a Eaton posi put in last summer with 3.73 Presision Gears. I think I took some teeth off the ring gear pulling out of a gas station a couple weeks ago. I have a Trans Go shift kit in the A4 that chirps the tires over 1/3 throttle. The new Nitto drag radials took their toll and something snapped. Oops. Oh, yeah, I have the stud girdle rear cover, also. Saving for a 12-bolt or 9".
Old May 1, 2004 | 05:38 PM
Greasepunk's Avatar
I have the AAM cover/girdle and 3.73's, so I should be safe running it hard right. I don't have special tires or anything.
Old May 2, 2004 | 07:21 PM
LT1Squirrel's Avatar
how upgraded is your upgraded 10 bolt?
Formula Steve
Sep 19, 2023 08:31 AM
Ericksd
Jan 20, 2016 06:07 PM
WobblySausage
Oct 7, 2015 02:44 PM
NewsBot
Aug 21, 2015 07:20 PM
Aug 17, 2015 09:50 AM
