Stock Shifter?
Old Sep 11, 2020 | 12:30 PM
1994-LT1-Eric's Avatar
Stock Shifter?
Hi,
I haven't seen this type in any photos. I'm assuming the 4 bolts on each corner and the shifter comes out? Inspecting it, it's old and needs replaced. I saw a nice one at Hawk's Motorsports that has great reviews.
Old Sep 11, 2020 | 12:37 PM
Re: Stock Shifter?
It's that case around the base of the shifter I'm not familiar with. Does that disassemble from the 3 little metal clasps around it?
Old Sep 11, 2020 | 12:49 PM
Re: Stock Shifter?
Answered my own question lol
Old Sep 11, 2020 | 01:14 PM
Re: Stock Shifter?
Make sure to pull the nylon isolator “cup” that remains in the trans ball socket, to reuse with the new shifter (unless Hawks includes one). They apparently offer a bronze replacement. When installing the new shifter, run a thin bead of RTV around the top of the trans opening.
Old Sep 12, 2020 | 12:06 AM
Re: Stock Shifter?
Will do! Found my friction disk springs broken in 2 places, and throw out bearing toast. The clutch fork seems pretty worn, so I'm ordering one with pivot T, and the transmission will go back in a couple weeks.
I'm going with an aluminum billet flywheel, SPEC Stage 2 Plus clutch kit, new pilot bearing, throw out bearing, and rear main seal while I'm in there. I replaced the master n slave cylinder already, new hydraulics too.
Old Sep 12, 2020 | 12:08 AM
Re: Stock Shifter?
95_LT1Z
Dec 19, 2010 08:35 AM
danhr
May 26, 2008 01:49 AM
MustangEater82
Feb 10, 2004 02:06 PM
camaroguy287
Jan 10, 2004 01:09 PM
