speedometer off??? 4:10 gears
Old Dec 8, 2010 | 08:24 PM
jklopez09's Avatar
I have a 1993 trans am that i recently bought. the guy that i got it from said it had 4:10 gears in the rear end. My speedometer reads 70 when im doing 55 and 90 when im doing 70mph. Anyways i was wondering if any of yall know how i can fix it.
Old Dec 8, 2010 | 08:29 PM
jklopez09's Avatar
Re: speedometer off??? 4:10 gears
also it is a t56 transmission
Old Dec 9, 2010 | 05:03 AM
The 93 speedometer is different than all other years of the LT1. There is a gear in the vehicle speed sensor (VSS) that can be changed. The VSS is on the tailshaft housing of the tranny, driver's side.
Minor point.... 4.10:1 gears or 4.10, not 4:10
Old Dec 9, 2010 | 08:08 AM
jklopez09's Avatar
thanks. do you know where i can get that gear at for the sensor?
Old Dec 9, 2010 | 02:16 PM
You have to calculate which DRIVEN gear you need for the VSS, based on which DRIVE gear installed on the tranny output shaft:
http://www.bgsoflex.com/cgi-bin/spee...n&givengear=18
This outfit should have the DRIVEN gear and if necessary the DRIVE gear.
http://www.transmissioncenter.net/sp...n_______va.htm
Noenav
Mar 1, 2019 07:38 AM
HarleyZ28
Oct 5, 2015 06:23 AM
QuickSilver02
Apr 7, 2015 11:12 AM
Cam's maro
Jan 30, 2015 09:21 PM
NHSZ28
Jul 25, 2002 07:58 PM
