Should I change dif. fluid?
Old Mar 12, 2004 | 06:05 PM
Jay-Roll's Avatar
I'm buying a rear from a gut on this board in a couple weeks. It has aprox. 60k on it. Just curious if I should bother changing the differential fluid before I put it in the car? If so, what kind should I use? Some kind of limited slip additive also? I want to make sure everything is kosher before it goes under the ride. Thanks
Old Mar 12, 2004 | 06:11 PM
simple's Avatar
peace of mind says change it and add GM limited slip additive, not sure on the part# tho. its cheap 5 or 6 bucks
if its an Eaton posi dont use synthetic oil
Old Mar 12, 2004 | 06:38 PM
Jay-Roll's Avatar
How come, I don't know much about rear end internals so any info would be good to know. BTW the seller put a MAC girdle on it so I'm assuming he'd have to had changed the fluid during that swap, just not sure how long ago it was. Thanks
Old Mar 13, 2004 | 09:22 PM
simple's Avatar
like i said, IMO it just gives me peace of mind and a point to start from for when the next fluid change comes around!
Old Mar 14, 2004 | 10:58 AM
Jay-Roll's Avatar
Ok then what about the no synthetic's with Eaton posi?
Old Mar 14, 2004 | 02:00 PM
simple's Avatar
the synthetic oil is to 'slick' for the clutch material.....synthetic oil and Eaton= death to the Eaton
its more technical then that but i am not the one to get into it!
its recommended by Eaton, Moser and Strange to use standard nonsynthetic gear oil when using an Eaton posi dif.
Old Mar 14, 2004 | 05:54 PM
Jay-Roll's Avatar
Ok I was assuming something along those lines. Thanks for the info, it's good to know.
warmeck
Aug 24, 2024 08:05 PM
PCLZ28
Dec 24, 2015 05:19 PM
warmeck
Mar 16, 2015 07:02 AM
captcorvette
Mar 7, 2015 12:37 PM
Timberwolf
Aug 9, 2002 11:24 AM
