Rising Stick
Old Jul 23, 2004 | 05:00 PM
burnout04's Avatar
Rising Stick
Lately my car just hasnt felt the same, its got around 70K miles on it. Its felt super grindy lately, I mean I know from the factory camaros were a little *course* but its felt a little more grindy than usual. I get a grinding feeling now a little from the stick but a lot from the gas pedal and the clutch. It doesn't seem right. Also when I punch it the stick seems to rise a bit. Not all the time, but more and more now. Which I Dont think is good at all. So if anyone knows what my problem might be, please let me know. Thanx
Old Jul 24, 2004 | 11:34 AM
Re: Rising Stick
The torque arm is mounted to the end of the tranny tailshaft. When you hit the throttle, the normal torque reaction lifts up on the rear end of the tranny. If the shifter lever is "rising" more than it used to, it could be the sign of a worn or broken tranny mount. A broken mount might also impart more "vibration" to anything that bolts to the body... e.g - the pedals, etc. While you're under there checking the tranny mount, look at the torque arm bushing for damage or excessive wear.
Old Jul 24, 2004 | 09:53 PM
burnout04's Avatar
Re: Rising Stick
This might be a dumb question, but better asked than to not ask at all, my first Z, where exactly are the tranny mounts, and the torque arm, and if they are broken or worn...would it be pretty easy to tell?
Old Jul 24, 2004 | 10:24 PM
JoeliusZ28's Avatar
Re: Rising Stick
crawl under your car and you will see a somewhat large part, that is holding up your transmission. Its right on the bottom of the car, you cant miss it Its a matter of 3 bolts to remove it. (and of course a something to substitute holding the trans up)
edit: here's a pic of the my car's tranny mount: http://memimage.cardomain.com/member...0_173_full.jpg
Old Jul 25, 2004 | 01:09 AM
RedHottG2's Avatar
Re: Rising Stick
Yea I'm pretty sure your tranny mount is busted up under there. Just replace it with an Energy Suspension poly unit and you should be good. There around $20
Old Jul 25, 2004 | 10:27 AM
burnout04's Avatar
Re: Rising Stick
Ok so in that picture is it that rubber grommet, almost kinda like a sandwhich that holds that metal part? oh and btw redhott where can I buy that part?
Old Jul 25, 2004 | 04:38 PM
RedHottG2's Avatar
Re: Rising Stick
Try Summit, Jeg's, or thunder racing..one of them will have it. I think I got mine through Summit if I remember correctly, it was a long time ago.
Quickss96
Jan 29, 2016 05:56 PM
SEOJustin
Sep 24, 2015 04:39 PM
DarksideII
Parts Wanted
Sep 23, 2015 11:14 PM
tdigger9899
Sep 7, 2015 10:56 AM
dolfan324
Jul 17, 2015 10:34 PM
