reverse lockout wiring help!!!
Old Dec 8, 2003 | 11:18 AM
  #31
rlax31's Avatar
I'll tell you in a couple weeks when I get around to hooking it up...
Old Dec 8, 2003 | 11:48 AM
  #32
Jason Dove's Avatar
I didn't hook mine up, and it's soooo hard to get into reverse there's no way to 'accidently' put it in. I pretty much have to 2 hand it to get my car into reverse.
Old Dec 8, 2003 | 12:30 PM
  #33
SWINGRRR's Avatar
Technically no. Will it work. Probably. Test and see if you get 12v with the key in the run position.
The pink wire that Injuneer is talking about goes to the ignition system. It will work for a power source as it gives 12volts with the key in the run position.
For the life of me I cant find any pink wire coming out of the TCC in any of the diagrams I have. The only one close is after the brake switch that goes to the "Gauges Fuse" in the I/P box.
Old Dec 8, 2003 | 12:38 PM
  #34
SWINGRRR's Avatar
OKOKOK. Finally found it. Injuneer was 100% correct. There is a pink wire coming out of the TCC the goes dierctly to the IGN fuse on one of my diagrams. I will send it to you. Sorry for any confusion I may have caused.
Old Dec 9, 2003 | 01:34 PM
  #35
95patriotZ's Avatar
I went under the car today to do the actual wiring and saw that there is actually two pink wires coming from the TCC connector. Which one do i use???? Or just use either one???? Any help would be awesome. And since I just need a 12v+ source, is there another wire in that connector that will work if I can't find which pink one is the right one? Thanks guys!
Old Dec 9, 2003 | 02:08 PM
  #36
SWINGRRR's Avatar
The pink wire you want is coming from pin "E" of the connector. The other pink wire goes to the trans temp sensor.
In short you want the pin in the middle row all by itself. Double check the wire for 12 volts before you tie it all up and take the car off jack stands.
I'll e-mail you the connector view and the pinout.
Old Dec 9, 2003 | 03:32 PM
  #37
95patriotZ's Avatar
Now, when you say pin "E" is that a pin on the pcm , or is that the pin on the tcc connector?
Old Dec 9, 2003 | 04:40 PM
  #38
SWINGRRR's Avatar
On the connector. When you look at the inside of it. There are 4 rows of pins. They go:
OOOO
O
OOOOOO
OO
You want the pin all byitself.
Old Dec 10, 2003 | 05:39 PM
  #39
Janny's Avatar
Hey Patriot did you get that thing wired in yet?
Old Dec 10, 2003 | 08:11 PM
  #40
95patriotZ's Avatar
Janny- Yeah, i got it wired, I tested that pink wire that swingrrr was talking about and it was a 12v source. The only problem is I am waiting on a clutch to come, and I am going to install clutch/tranny and get everything back in order this weekend. I will let you know how everything turned out
Old Dec 10, 2003 | 08:31 PM
  #41
Janny's Avatar
Thanks man, I'll wait on you for the simplified story of how this goes together.
Old Apr 13, 2005 | 08:42 PM
  #42
GMH94Z28's Avatar
Re: reverse lockout wiring help!!!
95patriotZ
Did you get it wired up and test it? I am just now hooking my lockout up but i did the tranny swap a while back and was wanting to hook it up. Thanks
Old Apr 13, 2005 | 11:52 PM
  #43
If you have a pink wire in the old A4 connector, simply connect a volt meter to the pink wire, and to ground, and verify that it is in fact +12V switched power. Shouldn't be all that hard.
On the brown wire, you could pull the harness connector off the PCM, and do a continuity check from pin 6 on the connector to the end of the brown wire on the old A4 connector.
You will then know what apparently no one on the face of the earth, including the many people who have actually done the A4->M6 swap, knows.
Old Apr 16, 2005 | 12:01 PM
  #44
GMH94Z28's Avatar
I went to do this today and in the blue connector on the pcm on pin D6 i dont have any wire in that pin. Does anyone why this is? Thanks
Old Apr 16, 2005 | 04:25 PM
  #45
Are you sure you counted the pins correctly? If you were on the wrong side of the plug you may have been looking at D27, which is the only pin 6 from the end that would be empty.
