reverse lockout
Old Sep 11, 2006 | 06:17 PM
Dfetter84's Avatar
reverse lockout
anyone know what the symptoms are of a bad solenoid????
anyone ever replace the solenoid with the t-56 in on a lt1
howd you do it?
Old Sep 11, 2006 | 11:19 PM
Re: reverse lockout
Makes it extremely difficult to push the shift lever far enough to the right to engage reverse gear.
Check the fuse first.
Old Sep 12, 2006 | 08:51 AM
Dfetter84's Avatar
Re: reverse lockout
i checked the fuse and its good.....
anyone ever replaced it while the tranny is in
will it affect any other gears besides reverse
Old Sep 30, 2006 | 09:48 PM
JTR 96 TA's Avatar
Re: reverse lockout
Yes, I replaced mine while it was in the car. It's pretty easy. Get the car up on stands, locate the solenoid (The only thing that hooks into the shifter box portion of the tranny case). Disconnect the plug, and unscrew the solenoid with a wrench (I don't remember what size, but IIRC, a cresent fit and is what I used). Then, screw in the new one, plug it in, and reset the computer.
As for symptoms, when mine went out it made it physically imposible to put the shifter in reverse as it goes into lockout mode and would not engage to unlock it. (There's like a 3/8" round pin that blocks the shifter). Oh, and it will not effect other gears.
As a side note, ever since I put in the new solenoid, it is EXTREAMLY difficult to put into reverse. So bad that I took off my Lou's Short stick that was on my Hurst shifter because it took both hands to put into reverse, and some people (lady friend types) couldn't put it in reverse at all w/out help with the Reg. Hurst shift stick, I can put it in with one hand but it's still difficult. IF the solenoid didn't cost $89, I'd try another one. . .(the one I used was a brand new GM replacement).
Hope that helps,
-Justin
RUENUF
Mar 13, 2016 03:37 PM
blac94Z
Nov 4, 2015 01:59 PM
dolfan324
Jul 17, 2015 10:34 PM
jimlab
Oct 6, 2002 08:37 AM
Deadcarny
Aug 31, 2002 09:05 PM
