reverse lock out gone bad
Old Nov 24, 2003 | 07:53 PM
hot936spd's Avatar
hey i think my reverse lock is gone, can i get like a new, wire/sensor for it? if so where and how much? its very hard to get into reverse, thanks
Old Nov 24, 2003 | 07:58 PM
SWINGRRR's Avatar
How is it hard? Wont go up to reverse, or just shifing is tight?
Have you tried to re-adjust you rshifter cable?
Old Nov 24, 2003 | 11:58 PM
Did you check the fuse for the reverse lockout solenoid?
Shifter cable on an M6?????
Old Nov 25, 2003 | 01:03 AM
Prince's Avatar
What do you mean it's gone...need alittle more info.
Does it let you go into rev. while driving, or does it not let you go into rev. at all?
Just some fyi, when the rev. lockout solenoid is energized, it will allow you to go into reverse, not the other way around. Meaning, if you were to disconnect the wires to it, you will not be able to go into reverse (well you actually still can, you just have to force the shifter over). Just wanted to clarify that, cause there is alot of misconception on how the rev. lockout works.
BTW, Mine sticks once and awhile and screws me up as I try to shift into 5th.
Dave
Old Nov 25, 2003 | 10:42 PM
hot936spd's Avatar
it does go into reverse , jusy hard to where is the fuse kocated for the lock out seloined
Old Nov 25, 2003 | 11:09 PM
96z's Avatar
96z
Yeah Fred where is the fuse for the solenoid?
Old Nov 26, 2003 | 09:33 AM
Fuse locations vary by year. Shoebox's 95 wiring diagram shows that the skip shift, reverse lockout, EEC solenoid and EGR solenoid are all driven off fuse #6 in the underhood panel. Might also just be a loose connector on the solenoid. Or a loose pin (D6) on the PCM.
Driver's side of T56
Old Nov 26, 2003 | 10:27 AM
quicksilver97ta's Avatar
Just a thought, when I had clutch problems that was the first symptom. Maybe not for you, good luck.
Old Nov 27, 2003 | 03:03 PM
hot936spd's Avatar
i have a 93z , with origional transmisson, so where is the fuse for the reverse lock out selonoid???
Old Nov 28, 2003 | 12:09 PM
Suggestion.... include basic info, like year of car, trans and major mod's in a "signature"..... makes it a lot easier for people to try and help.
According to my Chilton's, in the 93's the reverse lockout solenoid is supplied by fuse #6. It is actuated (grounded) off of pin B1 on the ECM (light green wire).
Could have a problem with the fuse, the solenoid or the wire.
Victor Lamb
Aug 26, 2017 02:52 PM
HectorM52
Jul 30, 2017 11:46 AM
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
jermaine_rashad
Advanced Tech
Jan 4, 2015 02:32 PM
