Recommend a good clutch for my setup ---
Old Dec 13, 2006 | 03:38 PM
AlwaysCode390's Avatar
Lightbulb Recommend a good clutch for my setup ---
I will be running a 600 crank hp le2 setup with a 125hp shot of n20 through a m6 and 4.10 gears on 315s. What clutch disc do you guys recommend I run? The guy before me says he put in a "centerforce stage 2" but I dont think it will be up to the new task (pretty much stock now).
What clutch parts should I get/upgrade while I am doing the engine rebuild? Thanks ---
Old Dec 13, 2006 | 04:26 PM
asudecat's Avatar
600 at the crank with a LE2??? what do you have goingwith your set-up?
I've had sucess with two-spec 3 clutches
Old Dec 13, 2006 | 04:42 PM
I am hoping it will be 475hp at the crank, then add a 125 shot, so I guess 600hp isnt far off (he rates his le2 packages at 425 REAR wheel hp), hehe
Spec type 3 it is....says good for 680 ft lbs of torque!!! ---
Old Dec 17, 2006 | 01:02 PM
OK, so if I get the kit (CLUTCH DISK, PRESSURE PLATE, T/O BEARING, PILOT BEARING AND ALIGNMENT SHAFT. ) is that all I need or do I just need the clutch disk?! Thanks ---
Old Dec 17, 2006 | 02:06 PM
roguedriver's Avatar
Ok, i'll be the first to say it.... Get a Street Twin and be done with it. The kit will have everything you need.
Ken R.
Old Dec 17, 2006 | 02:10 PM
posenheimer's Avatar
Exclamation street twin
Go mcleod street twin... it will handle everything you can throw at it! Woth the 1000+ ... caution: rear end will becmoe weak very fast! I know from experience.
490 RWHP
Old Dec 18, 2006 | 07:53 PM
my94blackz's Avatar
Spec 4
Old Dec 21, 2006 | 06:28 AM
Thanks guys ---
DirtyDaveW
Dec 1, 2016 05:37 PM
marineengineer
Feb 9, 2015 03:59 AM
97TA-WS6-Con
Feb 1, 2015 01:01 PM
HectorM52
Jan 30, 2015 11:08 PM
