rearend/tranny questions
Old Jul 8, 2010 | 03:35 PM
englundjd's Avatar
alright so im building my engine first... probably not the best choice... but by the time im done im going to have somewhere between 400-500hp on the engine (i hope) and im hoping that the stock trany and rear end will hold on long enough for me to get them built... i understand that i wont be able to push it to much with that kinda hp going into a 3000 stalled tranny and stock rearend... i just want to know if the tranny/rear are going to hold it long enough for me to get the money for trany rearend upgrades if im nice to it as in not to many burnouts no racing at all...
Old Jul 8, 2010 | 05:04 PM
Kevin Blown 95 TA's Avatar
You don't have to use all the horsepower you got just to drive the car. If you drive normally, it won't be any worse off than it was before. Going down the interstate uses only a few horsepower. Your rear end, if it's healthy will do OK with an A4 in front of it with a soft converter, but your A4 may be short lived if you are hard on it and it's probably not new anyway, is it?. One thing I did to make my tranny last is to add a tranny cooler and a remote filter and deep pan with fins. I did build up the rear end a bit with a rear cover with support and a solid spacer instead of a crush sleeve. I got the tranny done later.
Old Jul 8, 2010 | 05:36 PM
toomchz4u's Avatar
They will be fine as long as you drive it like grandma going to church on sundays...
Old Jul 8, 2010 | 05:49 PM
TBSPW's Avatar
I did almost the same thing with my m6...blown apart quite a few rears but they were all stock ones...trans will pry hold awhile but a grenade will be sitting in the rear and if you stomp it you pull the pin
Old Jul 8, 2010 | 08:11 PM
It's not nearly as bad with an A4 as with a M6. My rear end lasted quite a while on my A4 car then I sold it to a guy with a M6 and he fragged it after 2 years.
Old Jul 9, 2010 | 01:39 AM
TBSPW's Avatar
lol...yeah clutch dumps kill those poor things...i blow them up pry once every 6 months to a year, im actually on rear number 4 and that one isnt far from its way out...and thats why im saving for my 12 bolt
Old Jul 12, 2010 | 04:22 PM
englundjd's Avatar
haha ok thanks guys ... drive it like grandma... hmm ok that would kill me but i wont hammer down haha... eventually im going to have the trany and rear end rebuilt and beefed up to handle it better. (knowing my luck by then ill be looking for a stroker kit or a supercharger/turbo setup >.<)
dluna333
15
Mar 13, 2015 12:30 PM
jasonduaine
Mar 7, 2015 09:44 AM
30thZ4C
Wheels and Tires
Jan 29, 2015 06:03 PM
95z_28_camaro_4_Ivan
Dec 19, 2014 08:48 PM
Hurin
Dec 13, 2014 07:38 PM
