Rear Swap Question
Old 03-23-2009, 10:06 PM
Godly96_SS_Here's Avatar
Rear Swap Question
I have a tired rear end in my 93 bird, I know it has 3.23 gears and is a 3 series carrier. But my questions is; I bought a rear from a 01' Camaro, it also has 3.23. Can I just swap what I need to my rear end? or does it not work that way? I am lost here, and dont know if this works. I heard that I have a torsen unit and the 01 is auburn? Can someone shed some light for me?
Godly96_SS_Here is offline
Old 03-24-2009, 02:29 AM
madhatter's Avatar
The brake setup is different but adaptable. Also need to know if the donor car is a 3 channel abs (abs sensor on top of pumpkin) or 4 channel abs(sensor on end of each axle.
madhatter is offline
Old 03-24-2009, 06:18 PM
I will check to see for both of those. But I am not trying to put the hole rear end under, just want to swap out the "guts".
Old 03-25-2009, 09:11 AM
camarobird92's Avatar
It will be 100000000 times easier just to swap out the whole rear. I would just slap it in there and not worry about the ABS.
camarobird92 is offline
Old 03-25-2009, 12:02 PM
Z28SORR's Avatar
http://www.torsen.com/
http://www.auburngear.com/
You could have done this!!!
Z28SORR is offline
Old 03-26-2009, 08:21 AM
Moderator
AL SS590 M6's Avatar
F-bodies that had LS from 93 thru 98 had Auburn clutch type LS.
F-bodies that had LS from 99 thru 02 had Torsens
The exception to these rules are the SLP cars (SS & Firehawk) could be special ordered with HD Auburns or T2s
AL SS590 M6 is offline
Old 04-10-2009, 06:42 PM
Originally Posted by Z28SORR
I suppose i could have, but i picked up a complete rear from an 01' for $40.00 disc to disc! Just seamed like a killer deal, trying to make what i have work.
Old 04-11-2009, 10:52 AM
Jayz Garage's Avatar
What is the differance between Auburn & Torsens? Can one be put in place of the other IE 2001 rear replacing a 1998 rear giving they are 3 channel,posi, limited slip, similar gears, etc?
Jayz Garage is offline
10-31-2016 11:09 AM
89 iroc zl1
3rd Gen / L98 Engine Tech
01-14-2015 02:18 AM
01-13-2015 09:52 PM
cmdeshon
01-04-2015 11:15 AM
95z_28_camaro_4_Ivan
12-19-2014 08:48 PM
Quick Reply: Rear Swap Question
