Rear gear oil and Tranny fluid
Would yall recommend synthetic in the rear end? Ive heard some do some dont but figured Id get a new fresh opinion. Also would I still need the GM additive if I go synthetic? and should I run 75-90 or 80-90?
Pretty much the same question on the tranny. Should I use synthetic in the tranny? I looked for a filter kit at the store today but they said one was deep pan and one was shallow. How would I tell which one I have?
I run Amsoil Severe Gear 75-90 + Amsoil Gear Additive for Gear Oil.
I know my rear had a whine on decel that I could hear over the radio
, and the Amsoil Severe Gear cleared it up completely!
Here's a study done a few of the most popular Lubes: Gear Lube Comparison
I would also think one of the Amsoil Transmission Fluids would be a good choice.
I run the Amsoil Manual Transmission Fluid in my car and it also cleared up notchy/sticky shifting... So I can only imagine that the Auto Fluid is up to snuff.
PS - You can probably also guess I run Amsoil Oil as well: Signature Series
, and the Amsoil Severe Gear cleared it up completely!Here's a study done a few of the most popular Lubes: Gear Lube Comparison
I recently swapped out my fluids with lucas products. The rear diff fluid and their ATF additive. Both fluids did make a difference. Especially the trans additive. It cleared up that annoying bearing whine and the chattering gears when the tranny gets hot. Im definately sold on the use of synthetics.
Brian
Brian
Sorry to hi-jack the thread
redz_02
Jul 24, 2002 09:42 AM
