Re-using Pressure plate...
Old Jan 9, 2009 | 09:22 PM
raroz28's Avatar
So I inquired to TRE Performance about getting a SPEC 2 kit.
My stage 3 only has about 40k on it, but it's started to slip. The clutch disc is a 6 puck and not meant to last for a really long time, I knew this going in, as the guys at SPEC put it this way... "We have one here with 10k and about 100 launches at the track."
But after inquiring, the guy at TRE told me I might not need to get the entire kit, maybe just the disk.
Opinions? I would assume he knows more about this than me, but I thought I'd inquire with you guys first. It's not a problem for me to just buy the entire kit, but if it isn't necessary, I'll use that extra cash I'll save and get a new flywheel.
Old Jan 10, 2009 | 11:01 AM
We have a forum for topics like this. "Engine" tech is only for engine topics. I'll move it to "Drivetrain" for you.
Old Jan 10, 2009 | 11:13 AM
raroz28's Avatar
thanks fred... How about a reply, I know you know the answer!!!
Old Jan 10, 2009 | 11:24 AM
CamaroBoy96Z28's Avatar
As long as the surface is true on the flywheel and pressure plate you can just replace the disc.
Old Jan 10, 2009 | 05:51 PM
wrd1972's Avatar
I machinist can resurface it. I have done mine twice.
Old Jan 10, 2009 | 06:35 PM
raroz28's Avatar
Anyway to tell if it's bad or not?
Old Jan 11, 2009 | 05:10 AM
Green96Z's Avatar
Look for any heavy hot spots on it. Light hot spots can be machined over, but any heavy heat damage or warping is unrepairable. The machinist who resurfaces it should be able to tell you what condition it's in.
Old Jan 11, 2009 | 05:44 PM
speed_demon24's Avatar
If you resurface the pressure plate you will decrease the clamp load unless they machine the mounting points the same amount. With that said there is a reason everyone replaces the pressureplate when they do a clutch install.
KYWes
Jun 14, 2022 06:52 AM
canuck94z28
Aug 19, 2015 05:50 PM
karpetcm
Aug 14, 2015 03:02 PM
350350
14
Aug 11, 2015 12:03 PM
Alibi
Aug 1, 2015 07:50 PM
