Preload on gears..
Old Apr 15, 2004 | 06:59 AM
importeater's Avatar
Preload on gears..
What are you guys setting the preload to for your pinion and carrier bearings? I got the solid pinion spacer that came with some shims, im assuming those shims are used to set the preload for the pinion?
TIA
Craig
Old Apr 15, 2004 | 08:22 AM
Well I looked at my service manual and it says to insert a .004" shim on each side to set the carrier preload. I went threw my shims and there isnt any shims smaller then .010". I have the Ratech Complete Gear Install Kit.. am I missing something here?? Should I just mic what I take out and put that same amount back in??
HarleyZ28
Oct 5, 2015 06:23 AM
Aug 24, 2015 06:41 AM
CoUnTryMuZiCZ28
Mar 8, 2004 11:08 PM
96z
Oct 15, 2003 08:06 PM
95Blackhawk
Sep 20, 2003 07:02 AM
