powerglide
powerglide
Is there anyone with a 3500 pound race wieght car running a powerglide? I was thinking od doing a pg. I know the 400 would be better but I want a pg and was wandering if there is anyone with the a working set up?
Re: powerglide
The first gear is too high for a 3,500lb car, unless it had a couple of thousand hp from a "mountain motor" or something. Standard first gear in a PG is 1.76:1. This is ~40% less gear than a TH400 (2.48:1). There are PG gearsets as low as 2.11:1. That might work, but then the huge gap between low and high would be a problem.
I don't think it would work.
Rich
Rich
Re: powerglide
Call Carl Rossler, he makes some of the best automatics out there.
http://www.rosslertrans.com/index.htm
Rich
Rich
blackztpi
Classic Engine Tech
Oct 19, 2005 07:56 PM
DarthIROC
Sep 30, 2003 07:06 PM
