possible 4L60E swap
Old May 29, 2009 | 06:42 PM
chya's Avatar
possible 4L60E swap
I have a 1994 S-10 blazer and a 1994 Camaro Z28
i havent found a solid answer but from what i have found it seems to point that the blazer has a 4L60E like my camaro.
which my trans in my camaro seems to have lost 3rd and 4th yesterday.
i was wondering if the blazer does have the same trans and would it work to swap them out.
Old May 30, 2009 | 09:11 AM
12SCNDZ's Avatar
If the Blazer is a 4.3, it'll have the same bell housing. If the Blazer is a 4X4, it'll have a different output shaft. The whole transmission would have to come apart to change the shaft.
Frank
CPT
Old Jun 1, 2009 | 07:34 PM
chya's Avatar
Its a 4.3 and its a 2wd
so it should fit right?
and will it be identical to the one in my Z?
gear wise and everything?
Old Jun 5, 2009 | 11:18 AM
chya's Avatar
TTT
i have the trans out of the truck and ready to put in the camaro.
is there anythingi should worry about
Old Jun 7, 2009 | 02:42 PM
chya's Avatar
I have The trans out of the Z now.
i noticed the tail shaft housing if a little different for the Z than the blazer for the trac bar. so im just going to swap them out. and replace any old or damaged parts while im inside
Parts Wanted
May 1, 2016 10:25 AM
David Dempsey
Mar 12, 2016 12:42 AM
gonzo275rltw
3rd Gen / L98 Engine Tech
Sep 7, 2015 04:46 PM
gonzo275rltw
Sep 5, 2015 06:26 PM
gonzo275rltw
Sep 5, 2015 06:24 PM
