Poly trans. monut
Old Mar 31, 2008 | 10:19 PM
  #16
caldercay's Avatar
Originally Posted by Injuneer
There are many people running poly tranny mounts, without switching to poly motor mounts. I have not seen much in the way of tranny tailshaft housings cracking. I've had [snipped]
Thanks for info, Fred. It's quite possible I've been reading this over in
another forum (LS1Tech). I've discussed this with Dave at Yank and
his opinion is this (quoted verbatim):
"... the poly mount will break the tail housing over time and is it not
needed unless the frame is tied together with a roll cage."
and from Chuck at FLT Transmissions:
"I think using the entire kit you'll be ok, most guys just use the trans
mount which I think causes problems at times because the motor is
moving more than the trans. I don't hear about the LT1 tails cracking
like the LS1 tails for some reason, maybe because the difference in size.
The only thing I don't like about them in a dailey driver is that
they can cause excessive vibration that you might not like."
(the "entire kit" refers to the complete poly engine/tranny kit I had
inquired about).
RUENUF
Mar 13, 2016 03:37 PM
David Dempsey
Mar 12, 2016 12:42 AM
68camaroboltz
Oct 5, 2015 01:46 PM
dolfan324
Jul 17, 2015 10:34 PM
