Code P0133
Old May 9, 2004 | 06:46 PM
cpt_bimes's Avatar
Code P0133
Alright guys i keep getting P0133 code..i replaced sensor b4 cat on driver's side...but i keep getting the code after i reset it..i mean is this a reccuring problem?...i have read that some cars are more sensitive than other on this...i gutted my left cat..but the right is not gutted yet. I have 02 sims...is this a bad 02 sensor? i think i'm going to switch the top two sensors and see if i still get the code...what do yall think?
Old May 9, 2004 | 08:11 PM
Eff's Avatar
Eff
i doubt its a bad O2 what does the definition for that code say?
Old May 9, 2004 | 08:23 PM
stereomandan's Avatar
P0133 Heated Oxygen Sensor (HO2S) slow response Bank 1 Sensor 1
I have the same code now. It cames and goes actually.
At first I had codes P1133 and P1153, insufficient switching on both front O2's
I changed my front O2's and the codes went away. Now about 2 weeks(400-500 miles) later, I got code P0133 on and off.
My gas milage is pretty good, so I don't think I'm running rich. I'm beginning to suspect something like a bad wire or ground wire or something jacked up in the PCM.
Dan
Old May 9, 2004 | 09:10 PM
Zeueses 97 RamAir's Avatar
o2s
your 02s are going out changed mine then the other side went out......change them both...
Old May 9, 2004 | 09:16 PM
Eff's Avatar
Eff
Slow respose could be a bad O2 or you could be running lean for some reason too. that could trigger the code if the computer isnt able to get it back to 14.7:1
johnsocal
Aug 29, 2002 10:01 AM
Darth Xed
14
Aug 7, 2002 12:21 PM
91Bird305
3rd Gen / L98 Engine Tech
13
Aug 5, 2002 08:42 PM
91Bird305
Aug 5, 2002 01:39 PM
BigDarknFast
Jul 8, 2002 01:37 AM
