Not sure about this car
Old Feb 7, 2011 | 03:10 PM
1996z28anthony's Avatar
I bought a 1996 Z28, has man extras on it. it's an automatic. i was just wondering the gear ratio of the rear end. it has moser axels and richmond gears. just not sure what the gears are. for instance running a steady 70 i tach around 2500 rpm, when i run 50 i tach around 2000-2100. Any ideas what the gearing is? is it low enough to be 4:10?
Old Feb 7, 2011 | 03:56 PM
450hplt1's Avatar
Re: Not sure about this car
Yes, they are 4.10's granted stock wheels and tires.
http://www.ringpinion.com/Calc_RPM.aspx
Old Feb 7, 2011 | 06:53 PM
Inserting the stock tire diameter (wheel diameter has no affect) in my 4L60E spreadsheet yields, for 4th Gear (0.696 O/D):
50 MPH - 1,871 RPM
70 MPH - 2,619 RPM
Note that stock tire diameter can be either 26.1" (235/55-16 tires on base Z28) or 25.7" (Z-rated 245/50-16 tire option). My calcs used 25.7".
Remember that the stock tach typically reads 100-200 RPM higher than actual engine RPM.
Jazsun
Dec 29, 2014 12:14 PM
1996LT1Z28
Middle Atlantic
Dec 4, 2014 09:37 PM
1996LT1Z28
Dec 4, 2014 09:20 PM
USAirman93
Nov 24, 2014 03:37 PM
