Not shifting to fourth
Old Jan 22, 2007 | 09:27 AM
madlt1's Avatar
I left a red light and it took off fine but it never hit 4th. I put it in N then pulled it back in overdrive still wouldnt go in 4th. i pulled over and when i went to take off it wouldnt go in 1st it would only go in 2nd and 3rd after that it felt like it was sliping in those gears. Reverse still pulls. Is it fried?
Old Jan 22, 2007 | 10:13 AM
Performabuilt's Avatar
Supporting Vendor
Could be but also sounds a little like limp mode , have you had it scanned and or do you have and ses light on
Old Jan 22, 2007 | 12:07 PM
12SCNDZ's Avatar
Any SES lights? What condition is the fluid in? Does it look dark...Brown or black? Does it smell burnt?
Your "A" solenoid has to be on for 1st and 4th. This could be a solenoid issue. If you need any further help, please feel free to give me a call. 302-250-1202
Thanks,
Frank
CPT
Old Jan 22, 2007 | 03:03 PM
madlt1's Avatar
The fluid and filter are fresh and there are no lights that came on.
Old Jan 22, 2007 | 03:12 PM
jay_lt4's Avatar
the trans in these cars can have codes in it and not set the ses light, have the car scanned with a scanner that can get trans codes, not just engine codes
the codes for solenoids usually reset each engine re-start
Old Jan 22, 2007 | 05:42 PM
Supporting Vendor
Agreed scanning it is the first move
Old Jan 22, 2007 | 09:42 PM
madlt1's Avatar
Ok thanks i will have it scanned. I will post the results.
Old Jan 23, 2007 | 10:22 AM
madlt1's Avatar
I had it scanned today. Andit said 1 2 selinoid was bad.
Old Jan 23, 2007 | 11:25 AM
Supporting Vendor
Well there would appear to be your answer, I would replace it fist then see what happens you can do it yourself in just a few minutes by dropping the pan ,Generally I replace both the 1-2 and the 2-3 solenoid as a set which you may want to consider
Old Jan 23, 2007 | 11:44 AM
12SCNDZ's Avatar
Hmm...Didn't you already hear this somewhere?...LOL Do you still have the phone number I gave you to order the solenoids?
Frank
CPT
Old Jan 24, 2007 | 11:21 PM
madlt1's Avatar
I changed the solenoids it shifts great now it slips in 3rd and 4th.
Old Jan 25, 2007 | 06:08 AM
12SCNDZ's Avatar
Did you notice alot of black sediment in the bottom of the pan? It sounds like your 3-4 clutches might be on the way out.
Frank
CPT
Old Jan 25, 2007 | 08:57 AM
Supporting Vendor
I posted that exact same question last night odd its gone but anyway was there anything in pan like he said?
LazyLemming
Aug 29, 2015 07:36 PM
Greg88
Aug 24, 2015 07:59 AM
War Engine
Aug 21, 2015 05:28 AM
weedog
Aug 15, 2015 08:23 PM
Cam's maro
Aug 11, 2015 07:45 AM
