not shifting
Old May 13, 2014 | 08:42 PM
kenx82's Avatar
Red face not shifting
speedometer not working transmission not shifting out 97 Z28
Old May 14, 2014 | 08:02 AM
Re: not shifting
You may get a better response on "Drivetrain" rather than "Car Audio and Electronics". I'll move the thread there for you.
Have you scanned it for codes? Sounds like a vehicle speed sensor (VSS) fault. Check the VSS (tailshaft of the transmission) and make sure the harness is plugged in to the sensor.
Old May 14, 2014 | 08:38 AM
12SCNDZ's Avatar
Re: not shifting
Like Fred said. The computer needs to see VSS before it will command the trans to shift. It's most likely either the VSS itself or the wiring.connector.
Frank
n2oblkz
Oct 22, 2015 02:31 PM
WobblySausage
Oct 7, 2015 10:09 AM
Bxlt1
Sep 29, 2015 03:18 PM
marlar98
Sep 19, 2015 07:53 AM
