Need evaluation of rear gear pattern
Old Mar 16, 2016 | 01:47 PM
cmaddox03's Avatar
I've swapped the stock 3.42 gears for 3.90 gears. I got the backlash to 0.011" & now tested the tooth pattern. I want to get a second opinion before I rip it apart to set pinion crush sleeve.
Attached Thumbnails Need evaluation of rear gear pattern-img_6180.jpg   Need evaluation of rear gear pattern-img_6183.jpg
Old Mar 28, 2016 | 11:30 AM
TGGodfrey's Avatar
Re: Need evaluation of rear gear pattern
Your backlash looks a tad off on the coast side of your ring gear teeth. Depth looks good. This is a new or used ring gear? If new then run it as is you'll be fine. Generally on a new ring gear you focus on the drive side of the tooth and its understood the coasting face wear can be off. Used gear you focus on the coast face more. Typically Backlash is set .006-.010. I set mine on the tighter side.
dueno
Mar 13, 2016 10:30 PM
TA Dreaming
Mar 7, 2016 12:43 PM
car_ramrod
Parts Wanted
Feb 27, 2016 08:42 PM
Stephen68
Feb 20, 2016 03:04 AM
Dub1973
Feb 14, 2016 10:19 AM
