Is my transmission going?
Old Jan 2, 2005 | 12:41 AM
pHEnomIC's Avatar
I have a 97 z28 with an a4. I am noticing that sometimes when im accelerating hard but not full wot, it shifts really jerky i think from 2nd to 3rd. It doesnt bother me much but freaks my passangers. It seems like its slipping and then catches really hard and jerks. I was wondering if its going and waht i can do to prevent it. It seems to work normal regular driving and wot. I changed my transmission fluid and filter about 1000 miles ago with dexron iii. My cooling system is working working too.
Is there anything i can do to fix this and is it an indicator or failure in the future?
BTW, how exactly do i check my trans fluid level. I took the pan off cleaned it out and i removed the line to the radiator i believe. I added 6 or 7 quarts and it seemed to work fine. When i put the dipstick in i t does have the redish liquid on the tip but i dont know how far up it is supposed to go. I had that reading at 6 and added another quart just to be safe.
Old Jan 2, 2005 | 12:47 PM
12SCNDZ's Avatar
Re: Is my transmission going?
Let's make sure the fluid level is correct first. Your dipstick should have a "crosshatch" area on it. The fluid level should be in the middle-top of this crosshatch area. The car needs to be on level ground, and the engine running.
Frank
CPT
Old Jan 2, 2005 | 02:21 PM
pHEnomIC's Avatar
I think mines always been above that, did i add too much or should i add more?
football4life
Oct 4, 2015 07:48 AM
4586
Sep 27, 2015 01:55 PM
cristian1311
Sep 12, 2015 08:16 PM
Daluchman1974
Sep 11, 2015 06:12 AM
92_RS_305
Sep 8, 2015 07:47 PM
