Major vibration trying to pinpoint.
Old 10-25-2013, 02:57 PM
lt1cruzin's Avatar
97 Formula auto 4:10 gears solid.tranny mount. Vibe started this summer after a long trip. Took driveshaft off cant tell if its out of balance. Its getting worse every time in drive.it. Really bad at tranny. If you put it in neutral going down highway its still felt but not.as bad. I'm thinking loose or.cracked.flywheel. Any other sujestions?
lt1cruzin is offline
Old 10-25-2013, 05:17 PM
parkers Z28's Avatar
Re: Major vibration trying to pinpoint.
If you have the transmission in neutral the driveshaft will keep spinning ...
however the drive shaft could still be the problem I've seen on here that other members
have had to replace there drive shaft due to bad vibrations
I would think that the vibration from the drive shaft should stay the same in gear or not ???
maybe the motor mount's ?????
my car does the same thing its not that bad. ...but it is noticeable
parkers Z28 is offline
Old 10-25-2013, 08:26 PM
lt1cruzin's Avatar
Figured it out. Busted output shaft. Can move it all over the place and can hear a grinding inside tailshaft when I do.
Old 10-25-2013, 09:48 PM
Can you replace just the output shaft ?
Old 11-01-2013, 06:10 PM
lt1cruzin's Avatar
Turned out to be a ripped poly tranny mount.
Old 11-02-2013, 10:26 AM
I thought you said you had a "solid.tranny mount" ???
Injuneer is offline
Old 11-03-2013, 09:18 AM
lt1cruzin's Avatar
Some call.it.poly. Some call it solid. Sorry. It was a poly mount. Was compleatly ripped one side.
David Dempsey
03-12-2016 12:42 AM
autoxr166
09-25-2015 04:21 PM
ryanhilsgen
9
09-21-2015 07:34 PM
CamaroSS30thAnn
09-08-2015 04:43 PM
RallyRed701/2
07-20-2015 11:18 AM
Quick Reply: Major vibration trying to pinpoint.
