loud screech when shifting
Subscribe
Jul 9, 2006 | 09:17 AM
So i let my friend drive my car yesterday, possibly the only person i would trust to do so. And we are driving around and i let him floor it a few times. The one time he does it we were in second already (the car is auto and i have a transgo) and when the car shifts into second all way up in them RPMs there was a loud screech. I used the search and found people saying it was the belt but he said it was something with the clutches. I dont remember what he said but i was wondering if someone could explain how it is the belt and maybe what hes talking about?
Reply
Jul 9, 2006 | 10:32 AM
Re: loud screech when shifting
It's the belt.
Frank
CPT
Reply
Jul 9, 2006 | 02:21 PM
I second that belt
belt's squeal screech etc. when they harden, when they slip, loosen.... usually slippage occurs under acceleration. replace belt and tensioner
Reply
Jul 9, 2006 | 04:35 PM
but why would the belt only make that noise when its shifting?
btw this only happened once so far
Reply
Jul 9, 2006 | 05:13 PM
Was it wet outside or anything? When it shifts it will put a lot of force on eveything, and a jolt.
Reply
Jul 9, 2006 | 11:11 PM
it wasnt wet
Reply
Jul 9, 2006 | 11:21 PM
Quote: but why would the belt only make that noise when its shifting?
The rapid change in RPM on a hard shift makes it squeal. Install a Goodyear Gatorback belt and it will probably cure it.
Reply
Jul 9, 2006 | 11:52 PM
ah shoebox i was waiting for your answer.. thanks to all i will get on it.. how much of a bitch is it to replace that belt?
Reply
Jul 10, 2006 | 01:36 PM
and whats the part number?
Reply
Jul 11, 2006 | 10:35 PM
You can find info on releasing the tensioner on the belt in the cam removal guide on my Tech Page. You will need to get at it from underneath.
Belt for my 1995:
Reply
Jul 11, 2006 | 11:59 PM
thanks.. why was it suggested i replace the tensioner?
Reply
Jul 15, 2006 | 11:00 AM
shoebox i couldnt find the belt tensioner info on your cam removal guide.
Reply
Jul 15, 2006 | 12:04 PM
Quote: shoebox i couldnt find the belt tensioner info on your cam removal guide.
It's in there...
Quote: Remove the serpentine belt by releasing the tensioner. A 13mm socket placed on the tensioner pulley bolt and pulled clock-wise will take tension off the belt. You will need to leave yourself room to get your socket and ratchet off, as the tensioner will return farther CCW with the belt off.
Reply
Jul 15, 2006 | 10:58 PM
thanks.. for some reason i couldnt find that.
Reply
Subscribe
