loud screech when shifting
Old Jul 9, 2006 | 09:17 AM
nodnarb481's Avatar
So i let my friend drive my car yesterday, possibly the only person i would trust to do so. And we are driving around and i let him floor it a few times. The one time he does it we were in second already (the car is auto and i have a transgo) and when the car shifts into second all way up in them RPMs there was a loud screech. I used the search and found people saying it was the belt but he said it was something with the clutches. I dont remember what he said but i was wondering if someone could explain how it is the belt and maybe what hes talking about?
Old Jul 9, 2006 | 10:32 AM
12SCNDZ's Avatar
Re: loud screech when shifting
It's the belt.
Frank
CPT
Old Jul 9, 2006 | 02:21 PM
84firebird's Avatar
I second that belt
belt's squeal screech etc. when they harden, when they slip, loosen.... usually slippage occurs under acceleration. replace belt and tensioner
Old Jul 9, 2006 | 04:35 PM
nodnarb481's Avatar
but why would the belt only make that noise when its shifting?
btw this only happened once so far
Old Jul 9, 2006 | 05:13 PM
Jazsun's Avatar
Was it wet outside or anything? When it shifts it will put a lot of force on eveything, and a jolt.
Old Jul 9, 2006 | 11:11 PM
nodnarb481's Avatar
it wasnt wet
Old Jul 9, 2006 | 11:21 PM
The rapid change in RPM on a hard shift makes it squeal. Install a Goodyear Gatorback belt and it will probably cure it.
Old Jul 9, 2006 | 11:52 PM
nodnarb481's Avatar
ah shoebox i was waiting for your answer.. thanks to all i will get on it.. how much of a bitch is it to replace that belt?
Old Jul 10, 2006 | 01:36 PM
nodnarb481's Avatar
and whats the part number?
Old Jul 11, 2006 | 10:35 PM
You can find info on releasing the tensioner on the belt in the cam removal guide on my Tech Page. You will need to get at it from underneath.
Belt for my 1995:
Old Jul 11, 2006 | 11:59 PM
nodnarb481's Avatar
thanks.. why was it suggested i replace the tensioner?
Old Jul 15, 2006 | 11:00 AM
nodnarb481's Avatar
shoebox i couldnt find the belt tensioner info on your cam removal guide.
Old Jul 15, 2006 | 12:04 PM
It's in there...
Originally Posted by from the "removing the intake manifold" section of the cam removal guide
Remove the serpentine belt by releasing the tensioner. A 13mm socket placed on the tensioner pulley bolt and pulled clock-wise will take tension off the belt. You will need to leave yourself room to get your socket and ratchet off, as the tensioner will return farther CCW with the belt off.
Old Jul 15, 2006 | 10:58 PM
nodnarb481's Avatar
thanks.. for some reason i couldnt find that.
n2oblkz
Oct 22, 2015 02:31 PM
WobblySausage
Oct 7, 2015 10:09 AM
Bxlt1
Sep 29, 2015 03:18 PM
marlar98
Sep 19, 2015 07:53 AM
Matt Dreessen
Sep 9, 2015 09:58 PM
