I'm in need of stall converter suggestions...
Old 09-30-2003, 02:21 PM
JEDCamino's Avatar
Question I'm in need of stall converter suggestions...
And if you guys had any advice I would greatly appreciate it! This Friday I'm getting a TH400 for my car, and I'll need a converter for it. I've got a B&M currently in my TH350, and it's been very good, but it's just a 2500 rpm converter. I'm wanting to go with a 3500 but all of the B&Ms, TCIs, and Hughes converters I've seen in Summit were no more than 3200 rpm or so, so I may end up buying one online. Have you guys had good luck with any particular brand? Any brands I should avoid?
Thanks!
JEDCamino is offline
Old 09-30-2003, 07:05 PM
JEDCamino's Avatar
Any suggestions?
Old 09-30-2003, 09:59 PM
JWINN's Avatar
If your running a Turbo trans and want a converter that has been claimed to have less then 1% slip then call Marty at Neil Chance Converters.
After running a B&M converter you will be shocked how the Neil Chance converter will perform. Night and day noticable difference!
I run a Neil Chance 2 peice converter. If I wanted to I could change the stall spped my self at the track and or if the tranny let go the converter is designed so a person can open it up to clean it.
IMO nothing truely compares to the Chance when it comes to quality and reliability. I guess if you had to purchase a alternative then Coan is ok but only if you go with a custome built converter from them. I my self am not a Coan converter fan but other you can speak to may have better to tell ya then I do.
Good Luck
JWINN is offline
Old 10-01-2003, 09:33 AM
JEDCamino's Avatar
Thanks alot, man. I'll definitely look into both of those.
Old 10-02-2003, 07:50 AM
FastZinTennessee's Avatar
Get a midwest converter- www.raceconverters.com
They will custom build one for you, and their prices are awesome. For my car, a 9.5" lockup converter shipped to me was $455. Because of the application I think it would be even easier for you.
John
FastZinTennessee is offline
Old 10-02-2003, 09:15 AM
JEDCamino's Avatar
Thanks John. You guys have definitely given me some more options, and I appreciate it.
thenewkid
04-12-2015 07:42 PM
marine1bird
10
01-25-2015 12:02 AM
Javier97Z28
09-08-2002 07:23 AM
veryslowfbody
08-22-2002 04:31 PM
TrouserSnake
07-22-2002 05:34 PM
Quick Reply: I'm in need of stall converter suggestions...
