Hurst Short throw problem?
Old Apr 2, 2008 | 06:16 AM
MTBSully's Avatar
I just put in my hurst comp plus shifter in my 95 z28 and i like the way it feels but when i took it for a test drive it kind of felt like something was out of wack. When you are driving through any gear, after the clutch is fully engaged and you are fully in gear, it feels like there is an ever so slight grinding. I had to turn the radio off and really get close to the shifter to hear it. You can also just barely feel it in the shifter. Is this normal? I read the instructions and it didnt say anything about adjusting shift points or anything like that. Did i miss something? Thanks
Old Apr 2, 2008 | 08:15 AM
Its normal for the aftermarket shifters to transmit a bit more gear noise than the stock shifter. They eliminate the big rubber bushing at the base of the stick, increasing the noise transmitted up the stick. Although you say you "feel" grinding, but then you got close to the shifter to "hear" it.
Did you keep the little nylon cup in the hole on the shift rail?
Old Apr 2, 2008 | 12:00 PM
MTBSully's Avatar
i think i did, i never really looked. I'll check. There arent any stop points i have to adjust or anything like that right?
Old Apr 2, 2008 | 03:00 PM
The Hurst Comp+ was their first shifter for the F-Body T56. I bought one in maybe 1995. It has no "stops" on it. I thought they replaced the Comp+ with the Billet+, which did have adjustable stop bolts..
You did put a bead of RTV on the top of the tranny surfaces as a "seal"?
Old Apr 2, 2008 | 05:00 PM
Jazsun's Avatar
I have the same shifter, I never really payed attention to it when I first put it in. But it has no stops as well. Does having stops really help, even if I have steel shift forks in my rebuilt trans?
nikolt1
Feb 27, 2015 09:10 PM
IRABuss
Sep 7, 2011 09:08 PM
xmatt
Sep 16, 2002 02:37 PM
94z28jbw
Sep 8, 2002 03:22 PM
CeeBee94Z
Jul 31, 2002 02:20 PM
