how do you tell if your 10 bolt is a 7.5 or 8.5
8.5s are pretty strong, my friend has one in his 69 chevelle SS thats pushin 500ish to the wheels, and he launches it hard, and its still in-tact. i believe there are different versions of the 8.5's too.
If you're thinking about swapping to an 8.5" 10-bolt (into your 4th-gen) forget about it
. Buy a used 12-bolt or 9" that's designed to fit!!
The 7.5" --> 8.5" swap has been done, but it's not the easiest thing to do (a lot of custom fabrication required) and there are easier "better" options available
If you're curious "how to tell" which diff is which, check out Richmond's website ... they've got a bunch of pictures of the diff covers, and each one pretty much identifies which diff it is
.If you're curious "how to tell" which diff is which, check out Richmond's website ... they've got a bunch of pictures of the diff covers, and each one pretty much identifies which diff it is
http://64.65.63.61/forums/showthread.php?t=473563
Or you could just look at the "Common GM and Dana differential ID" post stickied at the top of this forum.
Sorry I acted like a newbie and haven't noticed/read all of the stickies
, or were they just thrown in at random, sort of how LS6 blocks made it into "some" LS1 4th-gens??
I thought I read about them once before, and they apparently were no better (stronger) than the standard 10-bolt?
Just curious what criteria was used for putting them into the cars over the corporate 10-bolt?
One of my friends had one of those 9 bolts on his 88 iroc. They're not very desirable because parts are harder to find and more expensive I believe. I'm not really sure why they put those rear ends in some 3rd gens.
I'm not really knowledgable on the 3rd Gens, but it wasn't a "random" install. The Camaros had them installed with the "B2L" package (350-ci V8 in the IROC-Z coupe), and with G92 (Performance rear axle on IROC-Z coupe). They were also used in the 1986 Trans Ams. Not sure what other options triggered the install. I think all the 9-bolts had 3.27 gears.
Then there is the Dana 44, used by SLP in the first Firehawks in 1992. They only sold 25 of the cars, but apparently had a larger number of Dana 44's built for stock, and eventually sold them off for a very good price. The Dana 44's included 3.54 gears.
they had 2.77 in the 9-bolt also.....the parts for the 9bolt are very hard to find and its no better than the 10 bolt.
You best option is to buy a rear from strange or moser...you can't beat it for the price
Redbird
Aug 26, 2002 10:55 AM
