Help Quick Please in the midle of install, remove rear springs before Torque arm?
Old Aug 30, 2003 | 09:29 PM
IrocinthatZ's Avatar
is it really necessary to remove the rear coil springs in order to remove the transmission? or more directly the Torque arm? the book says so but i want your guys' opinion please be quick i am in the middle of install right now.
Louie
Old Aug 30, 2003 | 09:54 PM
LPEdave's Avatar
I doubt you'd need to remove the springs to get the torque arm out. Just lower the axle a bit for clearance, and see if you can wiggle the torque arm out. You should be able to.
Dave
Old Aug 30, 2003 | 10:30 PM
Grover's Avatar
You don't have to remove the springs, but it is easier if you do remove the torque arm. Worst case you will have to remove the front torque arm mount from the tranny.
Old Aug 31, 2003 | 12:54 PM
i didn't have to remove it. i just jecked up the rear end a little in order to get the bolts fully out and tehn stepped back and pushed it off. everything worked out a-ok with the springs in
87Aerocoupe
Jan 10, 2015 07:27 PM
Don 97 SS
Jul 11, 2005 08:50 AM
wytblur
Mar 2, 2003 03:40 PM
RedLineRev
Jan 23, 2003 03:51 PM
