Grinding Going Into 3rd
Old Sep 29, 2008 | 07:21 AM
1quickTA's Avatar
My transmission headaches continue...
The History: When I rebuilt my engine I found my trans was very low on fluid so I ended up having a shop but in all new bearings and install a RAM Powergrip clutch. It drove alright after that until my RAM clutch had its release bearing fail after a few hundred miles. I had the shop install an Auto Zone clutch (just to get the car back on the road until I get my new warranty clutch).
The Problem: Ever since then I have had an issue that when my car is just started and still cold, the trans grinds a bit when shifting into 3rd and only with 3rd. This goes away when the car is warmed. Any ideas as to the problem?
The shop will cover it "if it was their fault" but I am tired of continueing to pour money into this stupid trans. It had been at their shop more than I have driven it since June.
Old Sep 29, 2008 | 07:22 AM
1quickTA's Avatar
I also found someone give this as an explaination to someone who had a similar problem a while back:
Originally Posted by RedWS6TA
these trannys are fairly tough. what is wrong with yours is the syncro blocker ring is worn out. the syncro blocker rings job is to slow down the gear so that it will not grind going into gear. when it wears out you get the grinding noise you are referring to. did the guy that rebuilt the tranny replace all of the blocker rings or just the ones that were bad at the time? with the right parts a t56 can handle a lot of abuse
David Dempsey
Mar 12, 2016 12:42 AM
WobblySausage
Oct 7, 2015 10:09 AM
Bxlt1
Sep 29, 2015 03:18 PM
4586
Sep 27, 2015 01:55 PM
