GM dealership diffential service...
Old Aug 27, 2005 | 08:32 PM
dtp's Avatar
dtp
I never bothered asking them this, but I assume when they do differential service, the add the GM additive right? Anyone work at a dealer that could comment on this. If I was patient, I'd wait and call them on Monday... As in another thread, I get a little clunk out of the rear shifting, especially from drive to reverse and I verified it was not the u-joints today. So the rear gears appear old or someone may have left out the additive.
If the additiive was left out, could I add it myself?
Old Aug 27, 2005 | 09:27 PM
Re: GM dealership diffential service...
Sure, you can add it. However to know if that dealer put in the additive, you will have to ask them.
The only time you would hear a noise from the additive not being there is when you are turning.
Old Aug 28, 2005 | 10:13 AM
dtp's Avatar
dtp
Originally Posted by SMUJeremy
Also check the torque arm bushing.
Already checked and replaced that. After disconnecting the driveshaft I can tell that there is a little play in the differential which is what makes the noise when I go from drive to reverse. Probably something I'll just live with. Figured the fluid may have something to do with it.... Sounds like it doesn't from the other reply I got.
colts0455
Oct 4, 2015 09:47 PM
WPHIG2
Aug 27, 2015 06:37 AM
robcarnut
Mar 20, 2015 03:40 PM
2k2z28
Oct 11, 2002 05:55 PM
DansZs
Sep 2, 2002 07:03 PM
