GM dealership diffential service...
I never bothered asking them this, but I assume when they do differential service, the add the GM additive right? Anyone work at a dealer that could comment on this. If I was patient, I'd wait and call them on Monday... As in another thread, I get a little clunk out of the rear shifting, especially from drive to reverse and I verified it was not the u-joints today. So the rear gears appear old or someone may have left out the additive.
If the additiive was left out, could I add it myself?
Re: GM dealership diffential service...
Sure, you can add it. However to know if that dealer put in the additive, you will have to ask them.
The only time you would hear a noise from the additive not being there is when you are turning.
Originally Posted by SMUJeremy
Also check the torque arm bushing.
Already checked and replaced that. After disconnecting the driveshaft I can tell that there is a little play in the differential which is what makes the noise when I go from drive to reverse. Probably something I'll just live with. Figured the fluid may have something to do with it.... Sounds like it doesn't from the other reply I got.
2k2z28
Oct 11, 2002 05:55 PM
