Gear Vendors overdrive ?
Re: Gear Vendors overdrive ?
Originally Posted by Z-RATED94
Can you shift it into overdrive under WOT?
Are they getting any closer to being able to split all gears?
With the Gear Vendors Electronics, let say you have a 700R-4 Trans your shifts will be 1st, 1stOD,2nd, 2ndOD, 3rd, 3rdOD,4th, 4thOD.. By getting the whole set up your rpms never leave the sweet spot.. Should make for a really quick car.... I will be getting one before a power adder...
Originally Posted by Injuneer
Yes.... it make a nice "4th gear" in my TH400 setup.
Don't know. I run mine full manual, none of the GV electronics.... what trans are you planning to run it with?
http://www.gearvendors.com/hrgm4s.html
" The 700R4/4L60E was designed for improving GM's CAFE (Corporate Average Fuel Economy) ratings. Because of this it has a very low 3.06 1st gear and a very tall .70 overdrive ratio. This makes it the widest ratio automatic transmission on the planet (rear wheel drive) with only 4 gears. The GEAR VENDORS fixes the wide ratio problems so that when you want performance you have a gear between each of the factory ratios. This gives you approximately half the drop in engine rpm and torque multiplication (see final drive ratios).
You can easily have increases in horsepower in the 50+ range and torque boosts of 70lbs ft. just by gear splitting. With 8 forward gears available the motor stays in a narrow rpm band of performance. The .78 ratio of the GEAR VENDORS gives an alternative overdrive ratio to the very tall factory gear and the GEAR VENDORS can be used with virtually unlimited horsepower (if it is 1200hp or less it gets the standard product). "
jb4xx
Feb 2, 2015 10:00 PM
Caps94ZODG
25
Oct 2, 2003 06:30 AM
