which gear oil?
Old May 18, 2004 | 01:11 PM
96birdlt1's Avatar
which gear oil?
Which is the best gear oil to use in an A4 with fresh 3.73's (just broken in)?
Joe
Old May 18, 2004 | 01:16 PM
TedH's Avatar
If you have an Auburn differential, regular gear oil is what you want. Synthetic is too slippery:
From Auburn's site...
2.) What kind of oil should be used with an Auburn differential?
It is important when installing Auburn differentials that a high quality, non-synthetic 80w90 GL-5 oil, treated with GM or Ford limited-slip additive (also known as friction modifier) be used. Three ounces of additive will treat one quart of oil.
I have an Eaton in my Moser 12 bolt. They also require non-synthetic conventional gear oil.
Old May 18, 2004 | 01:38 PM
96birdlt1's Avatar
It is a SLP differential, I believe.
Old May 18, 2004 | 02:08 PM
TedH's Avatar
SLP nameplates other peoples products. Call SLP or check on their website for an FAQ.
HectorM52
Jul 30, 2017 11:46 AM
DirtyDaveW
Mar 15, 2015 07:01 PM
Elcojoe
Nov 17, 2014 10:27 PM
Jul 4, 2005 05:00 PM
redz_02
Jul 24, 2002 09:42 AM
