found a 12 bolt for $150! have questions...
Old May 30, 2005 | 01:26 PM
TransAmTONY's Avatar
My buddy wants to sell me a 12 bolt rear end that was made in 1977, it has drum brakes and no ABS. My question is if i convert this to disc brakes, and cut off the old shock mounts and move/weld them in the appropriate spots, have an appropriate length drive shaft, i should have a 12 bolt that will go into my lt1 right? After that i can buy all the parts i need for it and build it from scratch...
DOes this seem like a feasible idea? ITs gotta be cheaper than buying a 12 bolt from moser or someone else for $2200 or whatever.
thanks for your time,
tony
Old May 30, 2005 | 01:31 PM
94Zpower's Avatar
Re: found a 12 bolt for $150! have questions...
tony
Are u sure its a 12 bolt or just a 8.5 10 bolt?? the 10 bolt 8.5 were very comon for these years I dont think th e12 bolts even came srock on these cars
Old May 30, 2005 | 01:39 PM
13sectransam's Avatar
yep, they had 12 bolts back in the day.
Old May 30, 2005 | 02:06 PM
94Zpower's Avatar
Of course t hey did, I just saying that he should should check just to be sure.
Old May 30, 2005 | 02:41 PM
it is for sure a 12 bolt rear end.
Old May 30, 2005 | 06:08 PM
RamAir95TA's Avatar
It won't be an easy task. You'll need to make sure that it is the proper width (hub to hub), and that the axles are the correct bolt pattern and length. Not to mention:
Having the brackets welded on precisely in OEM location, taking into consideration the current dimensions of the new rear. You won't be able to just 'cut them off'. You'll need new brackets from Currie, Moser, GM, etc.
LCA and panhard rod bracket placement.
Spring perches.
And you'll need to fabricate a torque arm mount, since the rear you have definitely doesn't have one.
You'll end up losing ABS as well. IMO, it will be a big headache.
Old May 31, 2005 | 04:25 PM
The TA mount is the difficult part. I can give you a link to someone who did it. In the end, he figured to saved about $500 over buying a Strange or a Moser. He also said he doubted he would go through the problems (including a couple of TA mount failures) again.
Let me know if you want his name.
Old Jun 2, 2005 | 06:22 AM
yes please, i am very interested in doing this, thanks,
Tony
Old Jun 2, 2005 | 06:59 AM
87DJP2001's Avatar
To much work to make it fit. A 38 yr old rear isn't worth the effort even for $150.
Old Jun 2, 2005 | 10:03 AM
Tony
Check out "N20LT4Bird" on the F-Body.com forum.
http://www.f-body.com/forum/forumdisplay.php?forumid=2
maybe2fast
Mar 16, 2015 09:45 AM
94Z28LS1toLT1
Jan 17, 2015 08:29 PM
Catmaigne
Dec 25, 2014 12:16 PM
HuJass
18
Jun 24, 2002 09:19 PM
