Flywheel weight, stock vs steel...
Old Apr 22, 2011 | 11:44 AM
CALL911's Avatar
So I looked up and found that the stock factory GM iron flywheel weighs 20 lbs (http://www.lt1engine.com/tech/camaro...f-body-weight/)
I just ordered a steel fly wheel from SPEC, and found it weighs 26 lbs!
I was kind of surprised that steel actually out weighs iron. Does this sound strange to anyone else? Or is this accurate?
Should I expect to loose any HP from this heavier flywheel? Or will it not really equate to less HP just easier ability to launch?
Old Apr 22, 2011 | 02:21 PM
OBE1 95Z28's Avatar
Re: Flywheel weight, stock vs steel...
You don't lose HP but it will take a bit more time for the engine to accelerate as it has to turn a heavier flywheel. A way to look at it is the flywheel stores energy; some people perfer a heavier flywheel as the engine is less likely to bog when the clutch is released quickly during your initial launch (drag racing). Road racers perfer to go with a lighter setup as "launch" isn't involved with road racing.
Old Apr 22, 2011 | 03:45 PM
CALL911's Avatar
So it will equal a slower accelerating car? Or is it really for revving in nuetral?
oldschool
Feb 9, 2016 09:21 PM
canbaufo
May 25, 2015 12:01 PM
DirtyDaveW
Mar 15, 2015 07:01 PM
Noer
Feb 28, 2015 11:29 AM
MyShibbyZ28
Feb 14, 2015 12:05 PM
