Flywheel balancing question
Ok, getting ready to do the T56 swap, and I'm not sure what I need to do about the flywheel balancing. The afrashteh.com swap guide says to balance the new flywheel the same as the flexplate, but the guy I talked to says flexplates don't come balanced.
So I have a brand new SLP billet steel flywheel to put on a stock engine (minor bolt-ons). I don't want to take a chance of creating more vibration than there already is. Is it safe to bolt on straight out of the box? Can someone straighten this out for me please? Hopefully in the process saving me extra work, because I have no other transportation to a shop for balancing once the flexplate is out.
Thanks!
Thanks!
I use the SLP flywheel, but didn't do an A4 to M6 conversion. The FW was a direct bolt on with no need to balance. I called SLP and they assured me no rebalance was needed and they were correct. BUT I cant say for sure if it would be the same situation swapping from an auto. I would suggest calling SLP to see what they say. I think but am unsure that all LT1's are internally balanced and the flywheel and flexplate are zero balanced.
The stock LT1 is externally balanced, using a weight on the flywheel or flexplate. I went the other way.... T56 to TH400.
You need a flywheel with the correct weight on it. If the engine is stock, the weight is known.
Well, I called SLP today, and they said the flywheel I bought from them should just bolt on, it's neutrally balanced. When I get the flexplate off I'll check for any external weights or something, but as of now I'm just gonna throw the thing on.
Scratch what I said before. After a lot of research, I learned that a neutral balance flywheel is NOT GOOD for an externally balanced engine! (go figure ) Anyway, I talked to a guy at an auto machine shop, and he said it wasn't possible to balance my aftermarket FW the same as a stocker, even with both in hand.
But luckily I had a stock FW sitting in a box somewhere, so I'm just gonna resurface it and put it on. Just gonna sell the SLP one now.
stockssn2o
05-25-2015 08:54 AM
