Driveline help, broken
Old Dec 8, 2008 | 05:52 PM
96SSIndeed's Avatar
Ok, so i'm not sure what happened but i was racing at the track and all of a sudden i lost my drivetrain. I was in third and at about 5k it redlined and i let out. I then proceded(Sp?) to put the car in 4th and nothing happened. needless to say the car won't move in any gear, including reverse. if you put the car in gear and let off the clutch the speedo will move as if the car is going, but it doesn't Someone told me the fork broke or came loose or something, but i don't see how that would cause this. I didn't hear anything break and nothing leaking, one second it was pulling the next it was like this. The car is a 96 Camaro ss with a t-56 and a spec stage 2 clutch, about 3 months old. any help will be greatly appreciated before i start pulling it apart.
Old Dec 8, 2008 | 09:53 PM
If the speedo is working, it would indicate the tranny is turning the output shaft, since that's where the VSS sensor is located. That would rule out a clutch problem. Would appear to be a problem with the driveshaft, a u-joint or the differential gears. You should just be able to take a look underneath to see where the problem is. If the DS is turning, and the pinion yoke is turning, its the gears.
Old Dec 12, 2008 | 11:57 AM
96SSIndeed's Avatar
thanks, i believe it is the gears. i'm going get a set today.
Old Jan 17, 2009 | 03:16 PM
96SSIndeed's Avatar
turns out the carrier and spider gears shattered. not sure how that happened at 70mph but oh well. it should be ready monday.
Old Jan 17, 2009 | 04:35 PM
Be glad everything stayed inside the housing.
Old Jan 19, 2009 | 11:46 AM
camaro1fastz28's Avatar
i bet the rear broke that what mine did it the diff
mmf_1013
Sep 12, 2015 08:56 PM
Toxintwins
Sep 11, 2015 11:13 AM
maverickmk
Sep 1, 2015 09:17 PM
4586
Aug 13, 2015 10:11 PM
4586
Aug 2, 2015 01:45 PM
