Drive shaft angle question
Old May 8, 2009 | 04:54 PM
football4life's Avatar
Hi, so i had problems with my LT exhaust knocking aginst the frame. What I have done to stop the knock is Cut out 1/4" peices of steel and made brackets that fit inbetween the tranny cross member and the body.
My question is will this change the driveshaft angle to where it will hurt it?
I just tested it on a short drive down the road and I dont have any knocking or Any excess vibration coming from the driveshaft.
Just wondering what the guys here with more experince than i do think.
thanks
Old May 8, 2009 | 06:04 PM
LearJet's Avatar
Pictures of what you did would help.
Old May 8, 2009 | 09:33 PM
wrd1972's Avatar
You will perfectly fine. I have done a similar thing but I actually raised the tranny off the cross member by 1/2".
Did nothing to the angle.
Old May 8, 2009 | 10:19 PM
I will try to get some pictures up tomorrow. It is driving fine. I don't think the 1/4" is making any differnce in the driveshaft. And on the good note, There is no exhaust knocking.
Josh
Old May 9, 2009 | 02:08 AM
MikeGyver's Avatar
You could drop the transmission 6 inches and be fine as long as it's output shaft and the differential's pinion are parallel.
The U-joints are 90degrees out of phase so they cancel out each other's elliptical paths as the shaft rotates. Although, the higher the angle, the quicker the joint will wear and you can run into issues transfering power around severe "corners".
You should be just fine. Go 150mph and see if it vibrates
Old May 9, 2009 | 04:43 PM
Why not just put a level on the tranny, the DS and the pinion and see how it lines up?
Old May 10, 2009 | 02:51 PM
well I think its going to be ok. The angles did not change very much at all.
Here is a link to the Brackets I made they are about 1/4" thick. Let me know what you guys think.
http://www.fquick.com/garages/viewga...wimg&id=256915
http://www.fquick.com/garages/viewga...wimg&id=256916
http://www.fquick.com/garages/viewga...wimg&id=256917
oldschool
Feb 9, 2016 09:21 PM
Cam's maro
Dec 28, 2014 09:30 AM
squarehead
Nov 21, 2014 08:02 PM
BIGCOWL-IMP
Nov 21, 2014 09:40 AM
red
Jul 21, 2002 09:43 AM
