Dipstick Color
Old Dec 16, 2008 | 05:12 PM
4thgencamarofan's Avatar
Dipstick Color
Is the dipstick for the trans yellow or red on a 95 3.8??????
Old Dec 17, 2008 | 08:34 PM
trippin holyman's Avatar
oil is yellow, trans is red..
Old Dec 17, 2008 | 08:38 PM
OK thanks. So does it mean anythingif my fluid is like brownish color....other than I need new fluid.
Old Dec 17, 2008 | 08:41 PM
which one? the trans fluid or the oil? oil new is yellow/blondish, dark brown/black obviously is used.
if its the trans fluid that you are checking, are you using a white rag? trans fluid usually is colored so you can tell it from regular oil. i think its usually red in color. if it is indeed brown you might wanna get it checked out? at least try an atf flush and refill it if you can do that on your own. itll have lower lubrication power, so youll wear it out faster.
Sep 17, 2015 11:53 AM
Sep 11, 2015 09:44 AM
gonzo275rltw
3rd Gen / L98 Engine Tech
Sep 7, 2015 04:46 PM
gonzo275rltw
Sep 5, 2015 06:26 PM
gonzo275rltw
Sep 5, 2015 06:24 PM
