deep trans pan???
Old Sep 12, 2005 | 02:50 PM
93black-ta's Avatar
deep trans pan???
how many quarts of trans fluid do you guys use with your deep pans?
Old Sep 12, 2005 | 06:59 PM
revtime's Avatar
Re: deep trans pan???
Most don,t run deep pans due to ground clearance problems.
I myself have a cast B&M deep pan just sitting on the shelf in my garage because installed it is the lowest point on the car. If I were to hit anything the tranny pan would hit first even before my Hooker LTs.
To answer your question it adds about 3 quarts to the stock capacity.
Old Sep 12, 2005 | 08:52 PM
93black-ta's Avatar
hmmm... my deep pan is right at the same height as my milodon oil pan and LT's.
Old Sep 13, 2005 | 12:25 AM
revtime's Avatar
Your stock suspension helps you alot there, I would not lower the car if I were you. Hitting the exhaust is bad but not catastrophic. Hitting the tranny pan would do very bad things.
Your oil pan is protected by your K member is it not?
I have a cast pan as well, a stamped steel one may have better ground clearance.
Old Sep 13, 2005 | 07:57 AM
87DJP2001's Avatar
A little info about material used on the deep transmission pans:
Stamped steel will dent.
Cast aluminum will crack
Which one will leak after hitting say a speed bump??
Old Sep 13, 2005 | 11:25 PM
revtime's Avatar
Exactly. Which is why that cast pan is going to end up hanging on my wall. I can,t give the damn thing away.
Old Sep 14, 2005 | 12:09 AM
Steve69SS396's Avatar
I'm running a cast pan on my TH400 with a 10" TCI converter. It took 11 quarts of Redline transmission fluid to fill it up. Headers are more of a problem with ground clearance than the transmisson pan on a first generation Camaro.
Old Sep 14, 2005 | 05:46 AM
Loadre's Avatar
I'll paypal you $15 to send it to me.
Old Sep 14, 2005 | 11:41 PM
revtime's Avatar
It will take at least 50 to keep it from being modern art. I paid 3 times that. Besides it will look good in my bathroom.
Old Sep 15, 2005 | 06:47 AM
Loadre's Avatar
haha I might give you a yell soon on it, just had to buy a rebuild kit, restall the converter, buy a new torque arm so funds are really low.
Old Oct 27, 2005 | 09:35 AM
Frank89IROC's Avatar
I had the B & M cast aluminum deep pan in my 94 TA, went back to stock depth TCI cast aluminum with the drain. Stock holds 4 quarts, deep adds 3 quarts.
Old Oct 27, 2005 | 09:41 PM
ABA383's Avatar
You might want to look at the Derale pan. Its steel, but has cooling tubes in the bottom that air flows thru. Its supposed to work pretty well, but not hang any lower than stock, and costs like $75 from Summit...I'm thinking about it and I have a $50 Summit gift certificate....heard some good things on this board about it...
--Alan
Old Oct 28, 2005 | 01:51 PM
mike 96 ws6's Avatar
I have a TCI cast alum deep pan on my car now, but I'm selling some of my mods to try to keep my car {family $ bind}. I'll sell it if you want it.
It holds 2 extra quarts and requires no filter extension. My Pacesetter LT's hit a high object in the road before it does. My ws6 is stock ride heigth and I don't drive on any roads that I hit anything on underneath.
The only thing I wandered about with the TCI no-filter-extension design was if the higher location of the filter, as opposed to a pan using an extension, was if I could experience feed cavitation in a high g-force situation, like on the launch pad. But I have had no problem with this.
378000 Pan, Cast - GM 700R4/4L60E, 2 extra quarts
PCLZ28
Dec 24, 2015 05:19 PM
89 iroc zl1
3rd Gen / L98 Engine Tech
Jan 14, 2015 02:18 AM
siguy
Nov 27, 2014 10:07 AM
Rich_z28
May 6, 2003 08:38 PM
