Cooling System
Old May 24, 2014 | 03:59 PM
A's 91 Z28's Avatar
Cooling System
My '91 Z28 blew its radiator because the fan was rubbing so I bought a new one and fixed the fan so it wont happen again. However now my engine stays cool when I'm driving but, lets say I drive for a while and let it sit on it gets hot 99% sure I have air in the system, so what I'm wanting to know is what's the best way to bleed/burp it. I have done the squeezing the hose and it has gotten better but not where it should be. Also have a new thermostat. Just wanting to know the most effective way to get the air out.
350 tpi engine.
Old May 25, 2014 | 10:27 PM
4th Gen 4 Life's Avatar
Re: Cooling System
There are a couple tricks to get coolant out. One way is to heat the engine enough to allow the thermostat to open then let it cool and add coolant. Another way is bleeder screws if available.
94 Z28 A4 known mods... reworked ported heads/intake. Cam, 3" cat back flowmaster. unknown PCM tune. still researching car. ...
1990 RS HO 305, TH350(shift kit). 4 barrel carb, Cam, Long tube headers.
Old May 30, 2014 | 12:53 PM
A's 91 Z28's Avatar
Re: Cooling System
If I have a bleeder where would it be on my '91 z28 350sbc
Old May 30, 2014 | 03:28 PM
Re: Cooling System
I looked at a diagram of the cooling system and didn't see one.
Old Jun 7, 2014 | 08:58 PM
A's 91 Z28's Avatar
Re: Cooling System
Finally decided to pay a shop to get the air out of my cooling system. Still gets hot so, I have a new thermostat, new radiator, new coolant, and new sensor, and my fan works properly now. Now from what I've read its down to a head gasket, cracked head, or block. Is there anything else that might be causing this problem?
Old Jun 11, 2014 | 10:36 AM
Re: Cooling System
What temperature do you consider to be "still gets hot"?
Magenta_Hearts
Mar 25, 2015 10:24 AM
grgguy
17
Feb 23, 2015 07:57 PM
kksi
Feb 17, 2015 10:41 PM
89 iroc zl1
3rd Gen / L98 Engine Tech
Jan 14, 2015 02:18 AM
